Caporegime
- 9 Nov 2009
- Planet Earth
How is power consumption when running actual games??
It only has 4 threads
4 threads 8 cores
It's 8C/8T
To use 4 cores, you'd just set Prime to use 4 threads, it'd use the 4 cores. (2 modules)
I figured you were trying to be clever, but you failed at it, it'd be 4C/8T(If you call the modules cores)
You'd just change the affinity and set them to the cores not being used by Prime.
At 4.6GHz prime 8 cores - 350W
Unless I'm being silly?
What i would like to know is what will the FX-83## use with the 6950 on heaven with all its 8 cores running at 4.6Ghz
Is there any chance you could load up a game,say, BF3 and see what system power consumption is like??
480 watts
Piledriver 8350 at 4.6GHz 8 threads on prime95 large FFT
MSI Hd 6950 running heaven 2.5 benchmark 4x antialiasing full screen 1680 x 1050. (OCUK test spec)
8GB DDR3 at 1840MHz
Sandisk extreme 240GB
WD Black 1 TB
WD RE2 500GB
ASUS M5A99x
DGX Soundcard installed
2x DVB-T card installed
Seasonic 650x Gold PSU
Anything else?
Looking at the above, I am at 73% of the PSU, so a 650 gold would be about the minimum spec you would want if everything was as shown. This is unlikely in my opinion but may be possible in some games. A 7850 would use less power for about the same performance but if you are going for max on the graphics with SLI, x-fire, you would want more, a 750W upwards.
£35!, try at least £50 if not more![]()
