BF3 (Frostbite 2 engine) CPU cores usage.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
While i still have this CPU i thought i would run a little experiment to try and answer the age old question of how many cores BF3, with its Frostbite 2 engine actually uses.
GPU used; 7870 @ 1185 Core / 1450 Memory.
CPU used; AMD Phenom II x6 1090T
Game settings; Ultra Preset @ 1920 x 1080P (Going Hunting)
I down clocked the CPU to 1.2Ghz to get a definite Bottleneck to the GPU and then turned off a number of cores in the BIOS.
First running 2 cores, then 4 and finally 6.
GPU and CPU usage is underlined in red, as is FPS.
Starting with 2 cores at 1.2Ghz.
GPU usage = 27% / CPU usage = 99.8% / FPS = 31.
As you can see the CPU is completely pegged and the GPU is only just working at a quarter, FPS are also very low.
4 cores at 1.2Ghz
GPU usage = 76% / CPU usage = 91.1% / FPS = 47.
With the extra two cores at the same speed the GPU usage has increased dramatically, as have the FPS while the CPU has tailed off slightly. But the GPU is still bottle-necked.
6 Cores at 1.2Ghz
Now with 6 cores, again at the same speed, the GPU usage is almost maxed, the FPS have also increased again; now at a nice 70 FPS, the CPU is now at a reasonably comfortable level.
Good to know, but I don't think I'm going to be running my CPU at 1.2Ghz anytime soon :D
Well knowing that you can drop to such speeds and still be able to play at great frame rates gives you the option of big savings (relatively speaking) on the electric bill over the course of a year.
Nice comparison. Are there any other game engines that are as well optimised as this one? Common ones like Source or Unreal 3?
Other games running on the same engine as BF3 (Frostbite 2) will, yes.
As for other game engines, like the Unreal engine, i don't know.
But now that its been done its not unreasonable to think others will, or have followed suit.
Codemasters DIRT racing series...
Once you go past 2 cores, you only need to run them at 2Ghz to get a solid 50-60fps.
Excellent multi-threaded engine apparently.
Toms Hardware did an article on it a while back, basically asking how many cores do you actually need, or something like that.
