AMD Athlon X4 750K
Caporegime
29 Jul 2011
In acme's chair.
Where on earth did this spring up from? I haven't heard any rumours or speculation about these chips at all.
For the price, the specifications seem very decent. Will look up benchmarks in a few minutes.
http://www.overclockers.co.uk/showproduct.php?prodid=CP-330-AM
And the 740
http://www.overclockers.co.uk/showproduct.php?prodid=CP-334-AM&groupid=701&catid=1967&subcat=1946
I must admit I am a little confused as to why these chips exist, there is such a bounty of quad core AMD chips available. Right now you could go to the OcUK store and buy a new Athlon X4, a Trinity A8, a Trinity A10, a LLano A6, a LLano A8, a Bulldozer FX-4, a Piledriver FX-4 or a Phenom II x4... If i'm honest, I couldn't even tell you which chips outbench which anymore.
I have to agree there are so many AMD chips.
OCUK have made a mistake in the description of this chip though.
It doesn't have a GPU built in.
So it is FM2 without the onboard GPU, and an unlocked multi.
Yeah I noticed that mistake there :p
Could it be production issues on the A10? It does have the same 4 mb cache... which is one of the major bottlenecks in it's performance as far as I can tell. It does seem a bit odd when you could get a quad core piledriver for not a lot more which would be far more capable.
yeh seems like a pretty pointless cpu if going fm2 isnt it for an APU not a CPU?
If you want a cpu piledriver offers much better performance.
wasn't that long ago there was a mild selection of AMD CPU's here now there is tons!
They need to knock out 1 good cpu that can compete with intel
Bulldozer, Llano, Athlon and Phenom II need to go away... Piledriver and Trinity should stay.
lol. im getting 130fps in wow with my 8320 and that was when its at stock.
after 120fps it doesn't matter anyway as my 120hz monitor wont make any difference.
Actually after 60fps it doesn't matter in WoW, that's what its designed for, any higher and you start running into graphical anomalies (i.e the foggy island north of Icecrown).
Don't really see the point of this CPU, it's not really practical given the socket.
Agreed. Perhaps there will be some dirt cheap FM2 motherboards released without the unnecessary support for an on-chip IGP just for these Athlons. Though I doubt it.
Even then, can't help but think you'd be shooting yourself in the foot to buy it, upgrade path, you couldn't simply slot in an octo core, you'd be limited to an SR APU, or hope they make an SR Athlon like this.
Think I'd just get a Phenom II :p
