 - 7 Nov 2004
 - On another planet
i have seen what happened when my old tamiya car lost range and went crazy.Could you imagine the chaos a real one of those would cause lol
			What if you had one with, prepare yourself now, big rotors! Problem solved!
the one on the bideo didnt... it would need to be atleast 4x as big to carry anything fairly heavy
like this?
I take it you didn't watch the link I posted?
Try strapping that onto your single rotor design![]()
trex700 each blade is 700mm rotor diameter is obviously double that.62 inches is massive, what have you got?
Mines only 700mm ish, 28 inches.
I started with a hobbyking 250 which was stupidly hard to fly because of its size, bigger = more stable
these arent mine but the small one is a 450
the largest a 700
