snip
snip
Yup, the TOBS tub I was going to use isn't empty yet and so that forced me to make the journey to Ikea.
What sort of tin is that?![]()
http://www.ikea.com/gb/en/catalog/products/80102919/
all the refills seem to fit in them, i've got Trumpers, MWF and Vitos in mine.
i bought mine off ebay for about the same cost as petrol/dartford toll + cost of the tins. without the hassle of shopping in ikea!
Quick question. What's the difference between the Edwin Jagger DE89 and DE89L? All I can see is that one has a smooth handle, the other has a lined handle. Is either better than the other?
Hey guys, I've ordered the following items:
Edwin Jagger Double Edge Razor DE89 (Plus 5 Derby DE Blades)
Progress Vulfix 660 Pure Badger Shaving Brush
Feather Double Edged Razor Blades
Could have swore that I ordered some shave cream too but looks like I didn't. With shave cream, do you have to lather it with the brush or is it a case of just dipping the brush in and using the brush to spread it on your face? If you have to lather it, would I need a separate bowl to transfer some of the cream into?
Thanks
