You can generally tell if you've got the angle correct because you'll hear the blade cutting. The razor should sit with both the top and the bottom parts against your skin to hold the blade at the correct angle, there's a great tutorial on B&B here.
I don't hold my skin taut at all, I just move my face to stretch the skin slightly and haven't felt the need to do any more than that. I would suggest that while you're getting your technique sorted out that you just do two passes, with and across the grain and hold on with an against the grain pass until you're confident.
I think you were low on product for your lather. I have to use significantly more than all the guides say to get a good lather for three passes because the water here is so hard. Don't be afraid to add extra product into the bowl or even a few drops of water if the lather isn't up to scratch. A good lather is important and if that was below par then you wouldn't be getting the protection from the razor and that could help explain why you cut yourself. You said that the blood wasn't caused by cuts - If you weren't cut, where did the blood come from? You _did_ cut yourself!
I've not tried TOBS coconut but I love TOBS Shaving Shop and really like their Sandalwood. A lot people rave about TOBS Mr. Taylors but that doesn't do anything for me at all. I've got over two thirds of a tub left and I'm trying to swap it.
I've gone from hating shaving and only wanting to do it once or twice a week to really enjoying it and looking forward to my daily shave. I've now got two razors with a third on the way (a vintage Gillette Super Speed from my birth year), a couple of brushes and a handful of creams and soaps with more on the way.
Finally pressure - Don't use any! Let the weight of the razor do the work. I made the mistake of not remembering that on my second shave and my face was a bloody mess.
I guess I'm referring to cuts as once that draw quite a lot of blood, which only tends to happen one a very light and lightly raised mole under my nose. The blood came from "wounds" that stop bleeding once you've washed your face after finishing.
Cheers for the tutorial, I'll check it out and we also have hard water here so I'll try a bit more cream, maybe half a tea spoons worth. I'll check out the TOBS stuff once I've finished this bowl.
Thanks again
Similar to a DE89 but with more angle to play with. The smaller handles need a different grip though. I'd recommend using your ASCO blades first, it's a perfect pairing for me.
