GTFO!Cant you people just use a normal razor?![]()
Normal razors just cannot compare tbh and the price of blades is just ludicrous....but we all know that don't we?
The Weber is the one i use the most, before i bought that i was rotating between them all.
Shame they're not producing DLC heads anymore, look after it!Define 'normal'Cant you people just use a normal razor?![]()
Define 'normal'![]()
I've found the bluebeards revenge is really quite good stuff. However if I were to make any suggestion re your recent purchases it would be to use the Derby blades first if as you say this will be your first *proper wet shave* before going anywhere near the Feather blades.
As I've said before: those feather blades are sharper than a sharp thing on a sharp day. Be careful buddy.![]()
I wouldn't dare use it.Hi guys. I had my first 'proper' shave yesterday. Most areas of my face are the smoothest they've been for years. Have a few questions though.
- Okay, so my Edwin Jagger was all shiny before I used it. Now it looks quite grotty. How do I clean this thing?
Polish it with a dry cloth. Try and dry it after each use and always take the blade out when finished.
- A few hairs of the brush were coming off, onto my face. Is this normal? Also How do I clean the brush?
Normal at first. Clean in Borax as below
http://www.theenglishshavingcompany.com/english-shaving-cleaning-your-shaving-brush.html
- The lather, how thick? Also when I apply it to my face, if I don't shave that area within about 10 minutes or so, it seems to set and dry.
Thick enough to be opaque. You'll get faster so don't worry.
- After a couple of strokes with my razor on a particular area, all the lather disappears. Should I apply more or just keep shaving that area?
Only shave an area once. Try to avoid shaving an area with no lather. Leave it for the next pass.
If you can't find a 34C anywhere email the shaving shack & ask them to let you know when they get them in, that's what I did, didn't take long.
Hi guys,
Looking to get my dad a decent shaver for Christmas, he usually uses the typical shop ones but something like the ones in here would be something different.
What would people that recommend in terms of shaver, cream and blades etc. Not mega expensive but a good quality one.
Cheers
