Stock suggestion
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Here's my problem.
I have a CM Hyper 412S cooler on an Asus Sabertooth Motherboard.
That cooler overhangs DIMM 1 and 2, there is only just enough room to fit low profile RAM modules, there is about 5mm head room once fitted.
I'm looking to upgrade my Memory to 2x 4GB; PC3-2130 (2133Mhz)
The problem is you don't seem to stock such modules in low profile format.
If you had these CML8GX3M2A2133C11B In stock i would buy them from you, a competing retailer does, so despite the fact that i would prefer to buy them here i'm forced to go there.
I'm pretty sure i'm not alone in needing low profile Memory modules.
See pic for what i'm talking about, you can see the black modules under the cooler.
http://www.corsair.com/us/memory/am...annel-ddr3-memory-kit-cml8gx3m2a2133c11b.html
I don't suppose you can mount that cooler the other way around so that the airflow is straight toward the rear case fan? that way maybe it would give more clearance.
I could but 1 the fan will then overhang and 2 it works better that way round as its picking up the air flow from the intake fan instead of being up against the optical drives.
But thanks for the suggestion :)
It's your money! You do what you like :p I'd go for the 16GB 1866MHz kit if you are looking to be 'greedy' as you will actually notice the difference (16GB of RAM instead of 8GB :rolleyes: )
Edit, ah, thank you :) ^^^^^^ What are they like? i trust Corsair, i don't know that brand.
I want speed.....POWEEEERRRR!!!!!! :p I will never use 16GB.
