- 5 Sep 2011
- Nottingham, UK
Hi I am sorting out my mates computer for him (Dell Inspiron 580) and I have come across a big problem.
He wanted the hdd replacing with a bigger new hdd, so I got him this http://www.overclockers.co.uk/showproduct.php?prodid=HD-255-SE seagate 2tb sata 3 hdd.
I put it in, installed windows and it refuses to boot past the windows logo once windows has installed, I thought it may have corrupted, so I reformatted the drive and installed windows again, but the same thing happens, it just hangs at the windows logo (windows 7 ultimate 64 bit) and refuses to go any further.
So I thought I would bring the system back to mine, I have tested the new hdd in my machine and it works perfectly. Thinking the motherboard doesn't support sata3 drives in the dell, I put my sata2 500gb in it, so I could boot up windows, do a flash of the bios and install any sata firmware that I got from the dell website to try and fix the problem, but even my sata 2 (samsung f1) drive won't boot either, its doing the same thing.
I have reseated and swap tested all the ram and the gpu, checked all the connections and everything seems fine.
No HDD will boot, his old one has been wiped, but he may be able to get it back, but thats just a standard sata 2 also, like mine which wouldn't boot either.
I NEED HELP!
ANY IDEAS!
I NEED HELP!
ANY IDEAS!
I'd try to see the BIOS settings (including BIOS revision update, if any) and boot Safe Mode (F8) to see what it says.
