Asus website bug?
IC3
IC3
3 Dec 2011
Hi, today I installed a new windows on my PC and wanted to download some drivers of the website and when I try to download drivers for my asus p8z68-v the chipset it downloads 7.5mb file but on there it says 245mb.
Anyone had this problem in the past? A month a goo everything was fine and now there must a error...
7.5MB sounds about right.
They just have the wrong file size listed where it says 245MB.
But I need the whole thing since I dont have the cd...
Got it instaled the older version works fine, but i still get a message when windows boots up that a file is missing...
The chipset driver is just that and no more.
If you want other drivers (audio, LAN, USB 3.0 etc) then you'll have to download them individually from Asus or the manufacturer.
As it's a SandForce based drive you should have a go with the ATTO benchmark when you're not running other stuff on the PC.
This is what OcUK got:
It seems to be working fine but if you want to see the big speed results quoted by Intel (Maximum Read 550MB/sec, Maximum Write 500MB/sec) then ATTO is the benchmark to use.
To be honest, I dont really care just want real life peroformance e.g. booting, file transfer etc. :p
