£663 with keyboard
I have been reading that in canada the Samsung doesnt come with the S pen or keyboard
Not to bad, I hope it drops in price a bit when it's properly released.
Can't wait to see what you think off it.
Atom certain gives you a lot more flexibility than arm. Even without apps, you can always load up ie10 in desktop and up use full flash/silverlight for skygo, iplayer etc.
So with the ARM processor you basically can only use the apps within the app store, which is currently virtually none?
Sweeeeeeeeeeeetttttttttt price.
Now to do what ever I can to ensure I have that money for release.
The new Surface will debut in two editions in the United States and Canada: one with 64 GB of storage, priced at $899, a second with 128 GB for $999. Each model comes with a Surface pen but does not include Touch Cover or Type Cover add-ons ($120 and $130, respectively).
Surface General Manager Panos Panay also revealed additional specs for the Intel-powered device, which is capable of running the full spectrum of Windows desktop programs in addition to Windows Store apps:
Core i5 processor (clock speed not specified)
10.6" 9 ClearType with 1920x1080 full HD resolution
Full digitizer and ink support with Palm Block technology
Full-size USB 3.0 port
Mini DisplayPort (can drive an external display up to 2560 x 1440 resolution)
Upto 6 hrs iirc.
It'll just need to be charged lots.
Need to look into buying some two part rubber liquid stuff, pull apart a qi charger loop, ms charger adapter and combine the three into a sleeve.
That way at least every time you place it down it picks up some charge.
[RXP]Andy;23268372 said:Snap. My only concern is battery life, what are the rumoured stats?
