- 26 Aug 2012
- North West
Ok my setup:
I play at 1440p
Issue:
When in Hitman if I turn my settings to Max in everything, my entire PC crashes after about 5 minutes with me being forced to reboot. I can run the game in High in everything from either a single card or in Xfire and experience no crashes.
Every other game seems to work fine in Xfire. Furmark caused no issues. Temps seem ok not passing 60 odd on either card in Hitman or not passing 75 in Furmark. CPU passes intel burntest and prime95 perfectly fine, and in Hitman gets a max temp of about 45 degrees on any core.
I've tried backtracking drivers, you name it.
So any ideas? Surely Xfire 7970's should run Hitman in MAX settings easily (at 1440p)?
Ask me more questions if needed be (what I explained to you probably makes no sense as i'm fed up of typing out my problem so many times in different places lol).
- 3930K at Stock
- 2 Sapphire 7970's in Xfire.
- Asrock x79 extreme 9 Mobo ( recently replaced due to other faults, so it probably isn't related to this.
- 1200W Silverstone Pro Gold Plus PSU
- 2 Samsung 830 in Raid 0
- Crap load of other HDD's for storage.
I play at 1440p
Issue:
