- 26 Aug 2012
- North West
Get this when try to run 3DMark11
It says in the free edition you can run the Graphics Test 1-4 and physics and combined test.
But in the Application its self it says you need advanced edition for this wdf?
So it looks like it is the GPU fault
Card 1 Appears to be alright http://www.3dmark.com/3dm11/5056761 (card clock speeds seem to be a little wrong and its memory)
This was the one I thought had issues. Now to test Card 2.
Card 1: http://www.3dmark.com/3dm11/5056761
Card 2: http://www.3dmark.com/3dm11/5056839
Can anyone notice any issues here? FPS results look similar to me.
Also for one of them the core clock speeds seem to be wildy different for the exact same card.
Also just realised my RAM is running at 600Mhz. It's meant to be at 1600mhz. Could this be the problem here?
Ram should be 800Mhz 800x2=1600. Download GPU-z and run Heaven 3.0 with theses settings
API = DirectX 11
Tessellation = Normal
Shaders = High
Anisotropy = 4x
Stereo 3D = disabled
Multi monitor = disabled
Anti-aliasing = 4x
Full screen = enabled (yes)
Resolution = 1680x1050 or 1920x1080 and post screenshot at the end of the bench and also a screnshot of GPU-z min and max reading. To see the min and max just click on one of the reading.
Ok Il run Heaven at those settings. Do you want me to run a Single card or them in Xfire. Also how do i get the Min and Max reading from GPU-Z?
