- 27 May 2012
Well i'll try reseating the GPU and setting it to PCI-e as initial display, will see if it boots.
I take it you have the 2x 6 pin plugs going to your GPU?![]()
you might need a bios update to run that gpu too,a lot of modern motherboards needed it
Just be methodical about things.
Start by testing the components that do work. Boot with onboard graphics and run memtest etc, even use it as a web browser for the time being to test stability of the components already installed.
The next step as mentioned is to try your graphics card out in another machine, either a friend or a shop if you have to.
