Screen Grabbing in Windows 8
4 Mar 2003
Chatteris
With Windows 7 I could do the following:
Press "PrtScn"
Go to MS Paint, click Paste.
A screen grab of my entire desktop would appear in Paint where I could crop it etc.
With Windows 8 I do the following:
Press "PrtScn"
Nothing. No dump of my screen, no anything happens.
How can I take a screen dump under Windows 8 so I get the same functionality as detailed above?
Ta
Fine here. You must have some software installed that is hooking or overriding that system key, somehow.
Windows key + Print Screen
That does everything without having to use paint (when you do it the first time, a folder called screenshots will be created in the pictures folder).
