 - 20 Feb 2006
Now, I'm not a fanboy of AMD ok, Even though I've never had an Nvidia Card.
But, I've found AMD/ATI to always be better value, Well. After recent events with there dodgy drivers, I've had enough.
Why!. Well for starters, I've had a bug on my system for ages, which causes the Windows Explorer to stop responding many many times inside each hour.
After completely re-installing a fresh windows it was still there, Apparently it was the latest 12.10 Driver. So it was suggested that either A) I roll back to 12.9/12.8 etc. (which I didn't want because of other issues i didn't like) or
B) try the New 12.11 Beta 8 driver, this actually fixed the issue, But a world of issues came with it. namely a Crossfire Performance Disaster across some of my games library.
So...What's the point of this thread.
I want to change to Nvidia, I don't know if there SLI is better then Crossfire for microstutter. etc.. But I would like to know which to go for..
I don't know what my current two cards are worth, but I could spend around £200-£250 on a new setup..
Should I go with
GTX 570
GTX 570 SLI
GTX 580
GTX 580 SLI
Or the new 6 series, Which my mobo doesn't really support properly.
Should I go with
GTX 570
GTX 570 SLI
GTX 580
GTX 580 SLI
