And if it was the same scrote who nicked it, don't you think that even if you were stronger than them, that its still a bad cause of action. Aside from the fact that you may be arrested, as I already pointed out, you also face the fact that they know where your Nan lives and might make her life a living hell as revenge.
Yes I have thought this.. I only Jest with the above.
Should the scum be stupid enough to power the laptop up, and should I have enough time to get on it and get the info, and should the Police not do anything with it...
Then yes, I would investigate myself. Yes, I would attempt to track it down to an exact address through what ever means necessary.
At this point, I would likely call the police at the time when I know they are in, and If I knew the laptop was in there.
If even then they did nothing about it... Then, I would probably just go do it myself.
No news yet then?
If they have any sense it would have already been wiped by now, but you know the saying "thick as theives"
Just bear in mind that the people who you may be trying to catch have probably bought the laptop quite innocently. Unlikely that the thieves will keep it themselves.
yes this
btw is it a good laptop or what?
how much is it worth?
Log in, find their routers IP address, report to police (may need to enclose instructions on how they use this to catch them), done.
he clearly knew what he was doing....
