Hang on - have you checked the socket for the electric oven - there's usually a big red switch nearby.
It usually has the word 'OVEN' on or around it.
The top mini oven works, the main bottom one doesn't so guessing its ******!
This may well be a stupid question but my electric oven is broken (the gas hobs etc still work) call an electrician or someone else?
Yes I'm stupid![]()
It's almost certainly just the heating element which has blown. The part will probably cost no more than £10, so you can save a lot if you're prepared to undo a couple of screws at the back of the oven to expose the element and change it yourself (after turning off the power obviously...).
Doesn't work in what way, is it a fan over, can you hear the fan, or is there just no heat?
If the oven isnt getting hot.This may well be a stupid question but my electric oven is broken (the gas hobs etc still work) call an electrician or someone else?
Yes I'm stupid![]()
Also, sorry for the swearie Rotty! Must have auto corrected my word to a naughty word!
