Far Cry 3 Thread
I love it when you stumble in to enemy camp sometimes and all looks easy with max 5 guys to pick out. Then something goes wrong they call in support and you have 25 guys to deal with. All hell brakes loose then with a massive gun fight. (like that mission with weed burning - there must have been over 20 guys all armed).
That weed bruning mission was difficult because I was silly and only had space for one gun... i.e the flamethrower :(
does that mean there are no more pirates in the game when you reach the end ?
I captured all the outposts, and did all the side missions/path of the hunter/wanted dead quests before the final main mission, so for me, no there aren't any pirates, but as momo said, if you start shooting at friendlies, they will shoot back :p
Only things I didn't complete, are the collection of all the relics/crates/lost letters, decided I couldn't really be bothered with those at the end (or at least enough to go out of my way to collect them)
My Far Cry 3 has just done a 350mb update
Far Cry 3 PC patch 1.03 available now
NewsPublish Date 13/12/2012 - 10:23am GMT
Adjustable HUD will form part of update 1.04, says Ubisoft.
Far Cry 3 PC update 1.03 has been released, but it's not going to make much difference to the majority of gamers.
Patch notes:
Added Russian and Czech language support for Steam versions.
Fixed issues for machines that have more than 32 cores.
Fixed issues for activation keys bundled with ULC privileges. ULC content will now unlock during activation.
Improvements to playlists and rotation for User Made maps
The requested changes to enable an adjustable HUD aren't included with 1.03,
but Ubisoft has confirmed they will form part of the next update.
http://www.videogamer.com/pc/far_cry_3/news/far_cry_3_pc_patch_1_03_available_now.html
Far Cry 3 Patched to 1.03, Includes Multiplayer Playlist Fixes
The PC version of Far Cry 3 has been patched up, bringing the game up to version 1.03. The patch only appears to add proper support for Russian and Czech versions for the game, in addition to some stability fixes.
The update also fixes issues relating to the deluxe edition of the game, by allowing Steam owners to now properly unlock the premium DLC content during activation.
Finally, the patch adds improvements to playlists and rotation for user-made maps in its competitive multiplayer mode so players won't have to trawl through the same few maps on repeat anymore.
Fielding questions from the community, Ubisoft's community manager says that the team at Ubisoft has plans to release the HUD changes in the next upcoming patch. As we detailed in a previous news post, Ubisoft intends to make the visibility of the HUD and user interface optional for players who want to play the game without overlays obscuring the display. At the moment, it's only possible to hide it with a hack.
To download the latest patch for Far Cry 3, just log onto the game on Steam.
http://www.gameranx.com/updates/id/...-to-1-03-includes-multiplayer-playlist-fixes/
Fixed issues for machines that have more than 32 cores. This some kind of joke? Is the even such thing, like I can go and buy 32 core CPU?
Surely this is a typo.
For those interested, new SweetFX settings
Take from here
// SMAA on if no other anti-aliasing is used. Otherwise turn off as it will just waste resources.
// LumaSharpen if using blurry AA (FXAA or High MSAA). Otherwise it will strengthen aliasing and look awful. Keep it low regardless.
// Bloom kills FPS in this game but makes up for DX9 having much weaker bloom than DX11. Turn off if FPS tanks....
// LGG for darker shadows and SLIGHT color adjustments.
/ Choose effects /
// Set to 1 for ON or 0 for OFF
#define USE_SMAA_ANTIALIASING 1 //[0 or 1] SMAA Anti-aliasing : Smoothens jagged lines.
#define USE_LUMASHARPEN 1 //[0 or 1] LumaSharpen : Also sharpens the antialiased edges which makes them less smooth - I'm working on fixing that.
#define USE_BLOOM 1 //[0 or 1] Bloom : Makes bright lights bleed their light into their surroundings (relatively high performance cost)
#define USE_HDR 0 //[0 or 1] HDR : Not actual HDR - It just tries to mimic an HDR look (relatively high performance cost)
#define USE_TECHNICOLOR 0 //[0 or 1] TECHNICOLOR : Attempts to mimic the look of an old movie using the Technicolor three-strip color process (Techicolor Process 4)
#define USE_DPX 0 //[0 or 1] Cineon DPX : Should make the image look like it's been converted to DXP Cineon - basically it's another movie-like look similar to technicolor.
#define USE_LIFTGAMMAGAIN 1 //[0 or 1] Lift Gamma Gain : Adjust brightness and color of shadows, midtones and highlights (avoids clipping)
#define USE_TONEMAP 0 //[0 or 1] Tonemap : Adjust gamma, exposure, saturation, bleach and defog. (may cause clipping)
#define USE_VIBRANCE 0 //[0 or 1] Vibrance : Intelligently saturates (or desaturates if you use negative values) the pixels depending on their original saturation.
#define USE_CURVES 0 //[0 or 1] Curves : Contrast adjustments using S-curves.
#define USE_SEPIA 0 //[0 or 1] Sepia : Sepia tones the image.
#define USE_VIGNETTE 0 //[0 or 1] Vignette : Darkens the edges of the image to make it look more like it was shot with a camera lens. May cause banding artifacts.
#define USE_DITHER 0 //[0 or 1] Dither : Applies dithering to simulate more colors than your monitor can display. This lessens banding artifacts (mostly caused by Vignette)
#define USE_SPLITSCREEN 0 //[0 or 1] Splitscreen : Enables the before-and-after splitscreen comparison mode.
/ SMAA Anti-aliasing settings /
#define SMAA_THRESHOLD 0.05 // [0.05 to 0.20] Edge detection threshold
#define SMAA_MAX_SEARCH_STEPS 25 // [0 to 98] Determines the radius SMAA will search for aliased edges
#define SMAA_MAX_SEARCH_STEPS_DIAG 16 // [0 to 16] Determines the radius SMAA will search for diagonal aliased edges
#define SMAA_CORNER_ROUNDING 40 // [0 to 100] Determines the percent of antialiasing to apply to corners.
// -- Advanced SMAA settings --
#define COLOR_EDGE_DETECTION 1 // [0 or 1] 1 Enables color edge detection (slower but slightly more acurate) - 0 uses luma edge detection (faster)
#define SMAA_DIRECTX9_LINEAR_BLEND 0 // [0 or 1] Using DX9 HARDWARE? (software version doesn't matter) if so this needs to be 1 - If not, leave it at 0.
/ LumaSharpen settings /
// -- Sharpening --
#define sharp_strength 0.35 // [0.10 to 3.00] Strength of the sharpening
#define sharp_clamp 0.030 // [0.000 to 1.000] Limits maximum amount of sharpening a pixel recieves - Default is 0.035
// -- Advanced sharpening settings --
#define pattern 2 // [1|2|3|4] Choose a sample pattern. 1 = Fast, 2 = Normal, 3 = Wider, 4 = Pyramid shaped.
#define offset_bias 1.0 // [0.0 to 6.0] Offset bias adjusts the radius of the sampling pattern.
// I designed the pattern for offset_bias 1.0, but feel free to experiment.
// -- Debug sharpening settings --
#define show_sharpen 0 // [0 or 1] Visualize the strength of the sharpen (multiplied by 4 to see it better)
/ Bloom settings /
#define BloomThreshold 20.25 //[0.00 to 50.00] Threshold for what is a bright light (that causes bloom) and what isn't.
#define BloomPower 1.146 //[0.0000 to 8.0000] Strength of the bloom
#define BloomWidth 0.0122 //[0.0000 to 1.0000] Width of the bloom
/ HDR settings /
#define HDRPower 1.13 //[0.0 to 8.0] Strangely lowering this makes the image brighter
#define radius2 0.80 //[0.0 to 8.0] Raising this seems to make the effect stronger and also brighter
/ TECHNICOLOR settings /
#define TechniAmount 0.11 //[0.0 to 1.0]
#define TechniPower 2.8 //[0.0 to 8.0]
#define redNegativeAmount 0.88 //[0.0 to 1.0]
#define greenNegativeAmount 0.88 //[0.0 to 1.0]
#define blueNegativeAmount 0.88 //[0.0 to 1.0]
/ Cineon DPX settings /
#define Red 8.0 //[1.0 to 15.0]
#define Green 8.0 //[1.0 to 15.0]
#define Blue 8.0 //[1.0 to 15.0]
#define ColorGamma 2.5 //[0.1 to 2.5] Adjusts the colorfulness of the effect in a manner similar to Vibrance. 1.0 is neutral.
#define DPXSaturation 3.0 //[0.0 to 8.0] Adjust saturation of the effect. 1.0 is neutral.
#define RedC 0.36 //[0.6 to 0.2]
#define GreenC 0.36 //[0.6 to 0.2]
#define BlueC 0.34 //[0.6 to 0.2]
#define Blend 0.2 //[0.0 to 0.1] How strong the effect should be.
/ Lift Gamma Gain settings /
#define RGB_Lift float3(0.940, 0.910, 0.910) //[0.000 to 2.000] Adjust shadows for Red, Green and Blue
#define RGB_Gamma float3(0.970, 0.945, 0.970) //[0.000 to 2.000] Adjust midtones for Red, Green and Blue
#define RGB_Gain float3(1.060, 1.060, 1.060) //[0.000 to 2.000] Adjust highlights for Red, Green and Blue
/ Tonemap settings /
#define Gamma 1.0 //[0.00 to 2.00] Adjust midtones
#define Exposure 0.00 //[-1.00 to 1.00] Adjust exposure
#define Saturation 0.00 //[-1.00 to 1.00] Adjust saturation
#define Bleach 0.00 //[0.00 to 1.00] Brightens the shadows and fades the colors
#define Defog 0.000 //[0.00 to 1.00] How much of the color tint to remove
#define FogColor float3(0.00, 0.00, 2.55) //[0.00 to 1.00, 0.00 to 1.00, 0.00 to 1.00] What color to remove - default is blue
/ Vibrance settings /
#define Vibrance 0.15 //[-1.0 to 1.0] Intelligently saturates (or desaturates if you use negative values) the pixels depending on their original saturation.
/ Curves settings /
#define Curves_contrast 0.20 //[-1.0 to 1.0] The amount of contrast you want
// -- Advanced curve settings --
#define Curves_formula 7 //[1|2|3|4|5|6|7] The constrast s-curve you want to use.
/ Sepia settings /
#define ColorTone float3(1.40, 1.10, 0.90) //[0.00 to 1.00, 0.00 to 1.00, 0.00 to 1.00] What color to tint the image
#define GreyPower 0.11 //[0.0 to 1.0] How much desaturate the image before tinting it
#define SepiaPower 0.58 //[0.0 to 1.0] How much to tint the image
/ Vignette settings /
#define VignetteRadius 1.00 //[-1.00 to 3.00] lower values = stronger radial effect from center
#define VignetteAmount -1.00 //[-2.00 to 1.00] Strength of black. -2.00 = Max Black, 1.00 = Max White.
#define VignetteSlope 8 //[1 to 16] How far away from the center the change should start to really grow strong (odd numbers cause a larger fps drop than even numbers)
#define VignetteCenter float2(0.500, 0.500) //[0.00 to 1.00] Center of effect.
/ Dither settings /
//No settings yet, beyond switching it on or off in the top section.
//Note that the checkerboard pattern used by Dither, makes an image harder to compress.
//This can make your screenshots and video recordings take up more space.
/ Splitscreen settings /
#define splitscreen_mode 3 //[1|2|3|4|5] 1 = Vertical 50/50 split, 2 = Vertical 25/50/25 split, 3 = Vertical 50/50 angled split, 4 = Horizontal 50/50 split, 5 = Horizontal 25/50/25 split
Take from here
/ Choose effects /
// -- Sharpening --
/ Bloom settings /
/ HDR settings /
/ Curves settings /
/ Sepia settings /
/ Dither settings /
WoW did you look at the image in the photo album. That is some superb looking far cry 3 lol
Take from here
/ Choose effects /
// -- Sharpening --
/ Bloom settings /
/ HDR settings /
/ Curves settings /
/ Sepia settings /
/ Dither settings /
Where do you even get SweetFX from? All I see in that link is the settings for each game, no proper downloads.
Take from here
/ Choose effects /
// -- Sharpening --
/ Bloom settings /
/ HDR settings /
/ Curves settings /
/ Sepia settings /
/ Dither settings /
What kind of hardware are you looking at to run those settings well?
