- 15 May 2012
- Louth, lincs
what a mess and a stupid thing to try and do!I think if you take a knife to your CPU and break it that's at your own risk.
How about fishing line or dental floss to saw round the IHS?
wouldn't a fine dremel disc do the job? or do they not come thin enough.
Hello everyone,
it is my first post here and this thread is the reason I signed up on this great forum.
I bought an ivy I7 3770k in the summer and couple of weeks ago i decided to de-lid it as the temps were too high. I reckon I didn't spent too much time reading all threads available around about de-lidding, just watched 3 videos and i thought it will be a piece of cake.
I used a classic razor blade, that old fashioned type of, which is flexible. It proved to be difficult and in the end i managed to remove the ihs but I nicked in various places the cpu's pcb. Surprinsigly the cpu works, not fully but it works. The only problem I discovered so far is that channel A of the memory, the first 2 dimm's near de socket cannot be used. so i can't run in dual channel and i can't use the first two dimms at all, the motherboard always hangs with an error code displayed on the 2 digits display if I stick any memory module into those first 2 dimms. The 3-rd and the 40-th dimm's are ok. I haven't tried yet the integrated graphics, i have no clue if that particular area got damaged too or not, as i don;t have a hdmi cable nor a monitor with hdmi input. I'll buy an hdmi-dvi adapter and try the integrated graphics too in the next days.
If needed I can attach some pictures, I did my best to catch the nicks in detail but I think a far better macro objective was needed. I don't think it is any way to repair those traces, they're so thin, barely seen, maybe under some Leica microscope ( I worked with that in a cell phones plant). I was wondering about using some green pcb paint to cover the nicks/scratches then find some black rubberlike silicone sealant or epoxy and reseal the lid and finally send it back to RMA. Maybe those who'll open it later somewhere in some intel facility will understand that for a high end 3770k cpu we deserve some decent thermal paste or some indium soldering. After all the production costs for one 3770k are the same as for the cheapest Celeron they produce, what's the big difference for a drop of higher quality TIM? It's crap as I spent one month income for such a cpu and I know it was my mistake to try and open it but...I was not comfortable at all with temps around 70C all day long. Yes I was using the lousy cooler they provided along with the cpu in the box.
So where (in Europe) could I find some black sealant like Nickolp1974 linked here, apart from Amazon.
I'm from north western Romania.
cheers.
I've decided I'm going to do this, going to try fishing line I think
Did you rebond the IHS back to the CPU or just let the motherboard mount hold it in place?
