- 15 May 2012
- Louth, lincs
This maybe??
Without playing games of carbon fiber super strands, etc., the thinest strong wire you can buy is music wire, also called spring steel wire. It is very hard - it will damage most diagonal wire cutters - and can be bought down to hair thin. Anchor wire is a source for longer amounts, K&S Engineering sells 3' pieces in their hobby metals displays.
Edit. After thinking about wire/line method in theory sounds promising but there may be a problem, to make it work the pcb would have to be held in a diamond orientation so that you could try and cut through the corner which would give the least resistance but in doing so may damage the corner of the pcb
well done winston, cant wait to see your results.
