Hi,
Just wondering how easy it was to fit the 360 rad in the roof of the Phantom?
I was thinking of doing this myself![]()
Looks like the mobo block I want will have to wait,
out of stock and no idea when they'll be available
Grrrr![]()
I might have to get the new EK one, atleast most of it will be covered![]()
Make sure you cool the back of the VRM/MOSFET heatsink. Quite an annoying issue with the Sabertooth and RIVE. I glued a heatsink to the back of mine using AS Epoxy stuff.
Do you mean the plate on the back of the board that retains the VRM/MOFSET heatsink or the heatsink itself ?
I've got the Koolance blocks fitted on my RIVE and it retains the plate/thermal pads on the back of the board behind the VRM/MOFSETS so wondered if that's what you are cooling.
So even after fitting a mobo waterblock,
the back of the mofsets is still going to need cooling?
@Rossi
Thanks for the heads up on the fan,
as for touching something that gets hot
NO NO NO NO NO NO![]()
It's recommended, a lot of people do it. As you can see, it's not just a backplate on this board, it actually covers some FETs.
Run a benchmark or stress test and touch that "backplate" and feel how hot it gets.
) the Asus thermal pads look good though.
