New Corsair PSUs launched today!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
Please see the new Builder series PSUs from Corsair. These offer a new modular design to further improve your PC build by reducing unnecessary cables from inside your case.
Corsair Builder Series CX 430w Modular '80 Plus Bronze' Power Supply (CP-9020058-UK) @ £38.99 inc VAT
CX Series™ Modular power supply units are an excellent choice for basic system builds and desktop PC computer upgrades, offering high reliability, low noise, easy installation. The flexible modular cabling system lets you use only the cables you need, and 80 PLUS Bronze certified efficiency means less excess heat, lower noise, and lower power bills. The large-diameter, thermally controlled fan makes the CX Series Modular quieter at idle, and the large diameter reduces noise even when you’re pushing your system hard. And, the matte black finish, black-sleeved cables and black connectors help give your system a restrained, high-tech look.
- Modular cabling system lets you use only the cables you need
- Built and tested to strict standards for trouble-free installation and smooth operation
- 80 PLUS Bronze certified efficiency for low noise and lower power bills
Up to 85% energy efficiency means less heat generation and lower energy bills.
- 0.99 Active Power Factor Correction provides clean and reliable power.
- Universal AC input from 90-264V.
- A dedicated single +12V rail offers maximum compatibility with the latest components.
- Over-voltage and over-power protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components.
- Extra long fully-sleeved cables support full tower chassis.
- It supports the latest ATX12V v2.3 standard and is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems.
- ErP Lot 6 Compliant
- A three year warranty and lifetime access to Corsair¡¦s legendary technical support and customer service.
Only £38.99 inc VAT.
ORDER NOW
Corsair Builder Series CX 500w Modular '80 Plus Bronze' Power Supply (CP-9020059-UK) @ £49.99 inc VAT
CX Series™ Modular power supply units are an excellent choice for basic system builds and desktop PC computer upgrades, offering high reliability, low noise, easy installation. The flexible modular cabling system lets you use only the cables you need, and 80 PLUS Bronze certified efficiency means less excess heat, lower noise, and lower power bills. The large-diameter, thermally controlled fan makes CX Series Modular quieter at idle, and the large diameter reduces noise even when you’re pushing your system hard. And, the matte black finish, black-sleeved cables and black connectors help give your system a restrained, high-tech look.
- Up to 85% energy efficiency means less heat generation and lower energy bills.
Only £49.99 inc VAT.
ORDER NOW
Corsair Builder Series CX 600w Modular '80 Plus Bronze' Power Supply (CP-9020060-UK) @ £56.99 inc VAT
Only £56.99 inc VAT.
ORDER NOW
Corsair Builder Series CX 750w Modular '80 Plus Bronze' Power Supply (CP-9020061-UK) @ £69.98 inc VAT
Only £69.98 inc VAT.
ORDER NOW
Wow, awesome prices for a decent brand modular PSU. Think I'll treat my HTPC to a new psu and keep the one in there as a spare.
How long did it last? Did it die of natural causes?
It's lasted a good couple of years to be fair and I'll attempt to get it replaced under warranty. May be tricky as it was bought second hand and I'm not sure whether their warranty it transferable (although I do have a copy of the original receipt). Die of natural causes? As oppose to what, me chucking it around? :D
Can the 600W handle GTX670 powered Edition/i5 Ivybridge/1 SSD & 1 HDD
For my new build in January i was going to get the TX650M but seeing as these are newer and cheaper. (Also Green Text to match my Black and Green Colour Scheme) Should i go for these instead?
Thnx
I might grab one of these myself, i was already on the fence as i don't think my hx520w is cutting it these days when i try to overclock higher but wanted corsair again as it's lasted me donkeys years but was humming and hawing at the prices of the older models.
would have gone for the 750w but only 4 x SATA Power connectors is not enough they should have put more sata and got rid of the floppy connector.
The warranty is worthless !!, Corsiar doesn't refund postage costs for RMA's
My corsair CX600 (bought from overclockers) recently broke after 23 month, I packaged it up and took it to the post office, they wanted £30+ to ship to the Netherlands.
You all do realise we honour the full life of the warranty on behalf of Corsair! (And all other manufacturers too)
Sort the warranty replacement with OcUK.
