Reinstalling Windows 8
4 Jul 2011
England
I have an update key for Windows 8 and would like to install it, however I have no disk or means to actually install.
I've tried using the upgrade assistant but it just tries to make me buy it again.
Can anyone tell me how I can install Windows without a disk?
You can, kind of, go to Settings, change PC settings, General, Remove everything and re install windows.
You will need the product key
Hope this helps :D
And yes I have done it!
I'm running Windows 7 atm.
Forgot to mention that.
EDIT: Guy at Microsoft sorted it for me with a special link.
A guy at Microsoft gave me a link you go to and it just asks for a product key and then creates bootable media for you.
Worked really well.
I asked me to put my w8 disc in when I have done this....
As it needed some files..
You probably somehow removed the install files using disc clean up or deleted the USD folder hidden in C: that contains the install files.
If you know you did neither by mistake, then i have no idea why you needed physical media to re-install Windows 8.
