Great idea to cool the mobo,but its a right pain routing to the tubes
and to prevent them from kinking.
It's a good job I'm not in a rush as I've had the tubes in and out
so many times.
As the saying goes Rome wasn't built in a day.![]()
Thought about solid links like I'm doing, I know flow will be reduced slightly but it's much neater than loops ?
you should put this into the projects section mate
its a truly fine build your doing here.
Looks stunning!! You should think about getting the memory under water too![]()
