The Official Accelero Xtreme 7970/50 Thread
This is the best possible heatsink placement for the best possible VRM cooling on this card using the stock heatsinks.
You need to use Accelero permanent adhesive to get the best possible hold on the heatsink. Using thermal tape/pads or the included G1 glue is not ideal. It doesn't hold well like the adhesive does. Depending on where you get the accelero from it may come with the adhesive as standard. If you get an old accelero it will come with G1 temp glue.
You can buy Adhesive from Accelero here. It will he shipped from Hong Kong. If you want the best vrm temps and the best hold, i highly recommend you use it. - http://www.arctic.ac/en/p/accessories/587/thermal-adhesive.html
Notice there is a black heatsink. That is from this piece of kit here. - http://www.overclockers.co.uk/showproduct.php?prodid=HS-038-AL&groupid=701&catid=2330&subcat=787
It was only slightly better than the stock Accelero long thin heatsink which i had there before so you can use either.
