AWESOME R1600T Speaker deal for the next week this Christmas!!!!
20 Jul 2009
Midlands
Theyre back and at a price so EPIC its unreal! :D
Who wants a set of these lovely speakers for less than £50?? Plenty in stock but sure to sell rather fast! :o
Edifier R1600T Studio Plus 2.0 Monitors ** CHRISTMAS SPECIAL PRICE ** @ £49.99 inc VAT
The Edifier R1600T Plus is a professional low-noise amplifier with all wood enclosure. The high performance crossover provides superior coverage while magnetic shielding prevents interference. The 5-inch bass driver is designed using a composite cone structure for a truly balanced acoustic. Built-in, side-mounted controls mean volume, treble and bass are at your fingertips. Dual RCA inputs allow connection of two additional devices for maximum flexibility in your set-up.
- Professional low-noise amplifier coupled with high performance crossover.
- 4.5inch bass driver - designed using a composite cone structure for a balanced acoustic.
- Silk diaphragm 18 mm tweeter with aluminum phase plug.
- Side mounted rotary volume, bass and treble controls.
- All wood enclosure.
- Power Output: RMS 2 × 16W
- Signal to noise ratio: 85 dBA
- Distortion: 0.1%
- Bass unit: 5 inch (120mm), magnetically shielded, 6ohm
- Tweeter unit: 18mm silk dome tweeter, magnetically shielded, 4 ohm
- Input impedance: 10K ohm
- Input sensitivity: 550 mV ± 50 mV.
- What's in the box:
- 1 x Active speaker
- 1 x Passive speaker
- 1 x 3.5mm to RCA connector cable
- Audio connecting cable
- User manual
- Dimensions: 152(W) x 252(H) x 228(D) (mm)
100% UK Stock
Was £77.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
For £50 that is indeed a bargain for what are some outstanding quality speakers sound quality wise.
Do monitors have an active speaker with analogue bass and treble controls on them??
I'm not speaking from experience and happy to be wrong :) just thought that studio monitors were supposed to be as close to flat as physically possible.
In essence yes, but it's the built in amp that's controlling the levels not the speakers themselves. These aren't the sort of monitors you'll be producing stuff on, they are however very nice.
You are indeed correct which is why someone such as myself would spend circa £1k on monitors and have indeed done so.
They can act as monitors by leaving the dials at zero as indicated in the manual or adjusted if you want to have a gaming session or a listen to some music rather than creating it even if the creating part is more basic. But look at the price, someone who wants a play with music creation or to start off would find this perfect for the job.
what krk's you after mate, i've got both RP8's and RP6 G2's. The 8's are beasts and huge but for me the 6's are the perfect all-rounder. I sold some 5's I had as for me they just didnt have enough ummmph
At least the Rokit 6's, I have been looking at the VXT's also. I thought the 5's may be a little too small but then again the room I'm in isn't huge...
Indeed! The best price out there from what i can tell and by some way too and in stock! Its win win!
Get the order in before mid day Saturday for Xmas delivery! :D
