Caporegime
- 13 May 2003
- Warwickshire
Ok got quite a specific problem here, so bear with me.
My TV (LG plasma) has one of those annoying 1360x768 psuedo-HD resolutions, and my av receiver (Onkyo) refuses to play audio over HDMI from my htpc when set to a resolution other than standard 720 or 1080, as it requires a proper hd resolution in order to play the sound (the video is fine!).
Therefore I've plugged an HDMI cable into the TV straight from the gpu, bypassing the AV receiver, thinking I might run another HDMI cable from the gpu to the receiver but one that only carries sound, as if it detects that the htpc is kicking out a non-standard resolution, it won't play the audio.
Optical would be an option but I like my dts-HD etc, which optical won't do. I could just run my htpc at 720p as the sound then plays fine through the amp, but it looks awful on my TV unless the pc is set to the TV's native resolution.
1. Does anyone have a clue what I'm talking about
2. Any ideas if what I ask is possible, ie can I send only audio over HDMI from my graphics card?
Hope I've explained my problem properly. Trying to avoid having to replace my TV and / or receiver to fix this annoying problem!
Thanks!
Thanks!
