Catzilla new benchmarking program!
IC3
IC3
3 Dec 2011
Trailer custom benchmark arising in association studies ?ód? (Poland) Plastic, involved in the creation of games (Datura), Platige Image, which specializes in creating computer graphics, 3D animation and digital special effects (such as the Cathedral and created a city of ruins) and Allplayer a company known with the media player.
BENCHMARK SCORES
You can try out the BETA of the program on the link below.
http://www.guru3d.com/news_story/download_catzilla_benchmark_beta_version.html
Looks amusing, downloading now. If it has any of that dubpish music or whatever the kids are calling it today it's getting deleted right away !
It's only a trailer that has dubstep on.
I sometimes listen to dubstep while playing deathmatch on cod or CS. ;)
Wonder how long it'll take to get as tedious as Heaven...
Not long, I think they also helped out with Witcher production which is very demanding and is one of the best games in its category. ;)
Make sure to share your results and comment's on what you think about this benchmarking program! :)
Think it's cause I need to install intel HD Drivers says there out of date, that I will never use...
The link that Tonester0011 gave, the link to download doesn't work...
But you can download same beta from guru3d.
If you don't have an GPU for gaming use theres no point in running this benchmark.
Ran it, was pretty cool, will never run again due the music, got 7113 score, no idea if that's good of not. What did you guys get ?
My link worked fine, not sure why is isn't working for some?
Stock 3770k and 1125/1575 on the GPU.
Been having problems with my PC so took everything back down to stock :L
Edit: Doesn't show GPU, not that i checked. 7970@1125/1575.
Better music than Heaven :D
Thanks for sharing your opinion on this benchmark. :)
I will update my results once I get my 7950 up to highest clocks and my 2400 to 4GHz.
It's still a BETA, but next year a full benchmark should come out.
