Great build and looks very good IMO. I may nick your idea on my next log and put the connectors of the bottom rad towards the front, so I can easily add a T joint for draining. Neat idea and makes it simple.
I have some bitspower dual rotary 0-90 degree fittings, let me know if that's something that would sort out your gpu connection
Looks good though, that orange xspc tubing? If so it looks brilliant in the dark with a little backlighting.
Looks fantastic either way, really sold on those heatkiller blocks, just need to find stock of the nickel versions
Can't wait to get started with my build after seeing all these incredible setups![]()
Delivery costs steep?
Finding stock of the nickel blocks is proving harder then finding copper ones.
That's really really good, I paid near £30 to get slow post on two blocks direct from ek in Slovenia. Cuts costs a little, already looking at ~£400 on new blocks alone - the Mrs will be happy
Going any further then? Wc memory looks stunning...
Have you been tempted to oc the CPU yet.
Im really keen to find out what the difference is in cooling the mobo.
Glad you got it finished
Looks good dude, gonna use Crystal link on your next build?
How tight were those cables for the 1200i?
Cables fit okay with no pressure on them, it's just that they rest on the rad.
No one as said anything and considering it doesn't run that hot now
hopefully there won't be any issues
it's still working fine though
