Caporegime
- 18 Sep 2009
- Dormanstown.
Well the benchmarks are indication of its performance, if it out muscles the 3570k in situations, then its obviously competing with it, price aside.
You can't say "Intel is faster" (Meaning the 3570k) as it isn't in all situations, nor can you say the FX8350 is the faster CPU (Sure, it's got the more raw power, but it isn't utilised constantly) you pick the CPU that fits your CPU load, the 3570k will not always be the best, and you'd be wrong to then say Intel is faster.
The Intel overall isn't faster, because both CPU's going at it would see the 3570k trailing behind, it's software that makes the FX8350 slower, but as I've said before, Intel know this, they could turn the tide anytime they wanted to, but that's talking about something that doesn't exist.
You may not be a fanboy, but your ability at comprehensive thinking is lacking somewhat.
Arguably the 7970 GHZ edition can compete and best the GTX680, what's more expensive? The GTX680, price doesn't always have to indicate end performance. That doesn't to say I believe the FX8350 should be more expensive, due to its inconsistent performance its current price point seems fine, stock versus stock it can compete with the similar priced locked i5, but it can also taken on the unlocked i5 chip, and even get close to the 3770k in some situations.
If you recall AMD tried pricing the FX8150 at the same price as the 2600k, that didn't really work too well and it dropped like a brick.
As I said, there's enough CPU's in differing price segments to offer the consumer the CPU they need for their budget and their workload.
I won't deny that Intel have the superior CPU's, as that's obvious, the 3970k is much greater than the FX8350.
EDIT : I'm not even sure why I'm trying to argue with you, I won't be buying any Piledriver CPU's for myself, but I'm not going to throw blanket statements in the air and maintain a single line record.
