7950 7970 or 670
30 Apr 2003
Wigan
My trusty old 480 has finally bit the dust last night, so for the moment running off the 3770k in built graphics which aren't to bad tbh.
Well anyways i have £300 max to spend on a new card, but can't decided to go for either save abit of cash & go for a 7950 or max out for a 7970 or the 670.
670 is even or very marginally slower than a 7950. 7970 is only 5% quicker than a 7950.
7950 is your best option. Give it an overclock and you're good to go :).
While you are short of a graphic card at the moment, you could try overclocking your iGPU for now.
I managed to overclock my HD3000 from stock 850MHz to 1950MHz just by changing the frequency in bios :D
Not sure about the HD4000 though.
