- 4 Dec 2008
I just bought Spectre non Pro - silent, silent, silent
Pyropetepete - how hot do those cards get when under load?![]()
That is a very clean setup Antony Covered boards do look so nice.
not too bad are you crazy pyro thats very hot.
no wonder your name is pyro lol
are you using the 620 antec water cooler? i guess your gonna attach it to the cards?
what gpus are they?
you could have just said gigabyte 660ti's lol
are you gonna be able to fit the khuler in there though? if it does fit it will be very very tight
where will you mount the rads? you cant fit one at the back of the case due to the h100i blocking the space. that leaves the front 2 intake sections and the bottom intake.
whats the plan?
Finally finished my 1st WC rig
Need to get a better picture when I can be bothered getting the side panel back off. Finally managed to sort out the mass of trouble I had with my GTX 670 Power Edition and ended up buying an AX750 + Braided Cables and P67 Sabertooth, then OcUK told me they would refund the GPU :/
EDIT: Also need some black RAM nowOr white?
Better picture:
That looks very airy. Must be great temperatures.
Did you remove the hard drive caddies yourself? Where have you put your storage drives?
