Caporegime
- 29 Aug 2007
- Auckland
I can't help but feel we need a commentator, someone who understands chess and can offer impartial updates as to progress.
[FnG]magnolia;23448419 said:I can't help but feel we need a commentator, someone who understands chess and can offer impartial updates as to progress.
So far there is little to comment on, but I'll be an unofficial commentator of this thread![]()
Oh and I was working off the board Lysander posted....
OP you've made a mistake on my first move![]()
Is this right now? Still want to move bishop c8 to d7?
Just play the MS Chess Titans in Windows, it doesn't let you win as it always seems to draw for some reason when it loses![]()
LOL yes, it does that to me too. E.g. the AI player only had his king left and I still had my queen and a castle. Trapped the king in a corner, then the AI declares a draw!
If the opponent can't make a legal move, and isn't in check, then the game is a draw. Forcing a draw is a last resort move and the most annoying, but I've had to do it before (and had it done to me)
...bump, ugh whaat, what was that?
Nice boards, nice work. Like it.
Notation can be a lot simpler. You don't need to say where a piece already is, just where it's going to.
For instance, on the new board as it is now, Nf3 means you move the right-hand most Knight to square f3. You don't need to specify the left-hand most knight because it's impossible for it to move there.
K = King, Q = Queen, B = Bishop, R = Rook, N = Knight [since the 'k' is already taken for King].
If we moved the knight to square f3 and it captured another piece, this would be written Nxf3.
Final piece of info is that you never need to specify a pawn, there is no letter for pawn. So my opening move for the game would simply be e4. There is only one pawn which can move to e4, so there it is.
There are a couple more things you should know but we'll address them as they happen.
So my move = e4
If you are referring to Lightnixs move its shorthand for G1 -> F3
Not to be pedantic about annotation, but you don't need to specify the starting square unless two of the same pieces could get there, which of course can only occur with Rooks and Knights.
So rather than 1. e2 - e4, just state 1. e4.
