MOBO/Fans
25 Dec 2012
Hello,
Ive ordered the following as part of my build :)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-018-BX
http://www.overclockers.co.uk/showproduct.php?prodid=MB-391-GI
Looking at the Motherboard spec - I Can have 3 Fans connected to the Board.
There are 2x120MM Fans included in the Case - One at the front and rear.
I Can mouth 2x140MM Fans into the top/Front/Rear of the case - These will be taking the air out?
As I only have 1 spare slot on the board - Can a Splitter be purchased? i.e 1 Fan Slot on Motherboard = Powers 2 Fans ?
Most cases use 4 pin molex fans .What type of fan connectors are on the fans on that case?
Ive only just ordered the case/mobo so im unsure , however looking at the online PDF it appears there are 4 sys_fan area's
Looking at the Motherboard layout it appears they are 4 pin
Just had a look online and i `think` the case has 3 pin fans(at least the back fan looks like it is 3 pin)
So nelviss suggestion about that splitter is a good one
I personally do not like too many fans running off the mobo
1 front and 1 rear should be sufficient,unless you can use a side fan to further cool the gfx card,but your case has not got one
Try first. monitor your temps and post back ,if then they are considered too warm you could add extra fans then :)
Too many fans = more noise
For Stress testing I use Prime95 as Mentioned in http://forums.overclockers.co.uk/showthread.php?t=18383228 ?
What Can i Use to check Temps ?
How can i stress test the GPU/check Temps ?
I understand GPU Stress testing is using a full screen application , is there an application that can used to "Graph" your GPU Temps ?
I use HWmonitor to check temps. I use prime95 and or OCCT for stress testing. OCCT will show the temps as it runs the stress test actually
The fans will be 3 pin. You don't need another fan technically but maybe you'd like to add a Bitfenix Spectre LED fan to light the internals up so you can see in through the window.
If you feel the need to add more fans I did a review of their Hydra pro led/fan controller (link) Near the end of the review you will see the software I mentioned before in the pics ;)
Ive just got the computer :)
The below is Prime being run as shown here
This is my Desktop with CPU-Z/Prime95/CoreTemp Open - Screenshot Taken after 1 minute
Are the Temps ok ?
Not much change so looking fine to me :)
nice ,you could reapply the heatsink compound and refit the heatsink to try for a better fit and lower temps but probably not worth it imho
Maybe add a second fan to the heatsink
