Best 7950 drivers?
IC3
IC3
3 Dec 2011
I got 1204/1531 at 1.174v before and now it crashes...
24/7 I'm running 1100/1400 1.1v and on memory 1.62v The temps dont go above 61c but if the room temp is higher than 64-65c are the highest.
These are the moded drivers for anyone who wants to try them out 12.11 Beta 11 + CAP2 ULPS OFF
The drivers I got these clocks were 12.11 beta 11 and now i have 12.11 beta 9 moded. My friend told me that they are good and he has far more experiance in gpu's than me.
Stick with the official AMD drivers. If you're using modded drivers then there's a chance they are causing the problem.
I'm using 12.11 beta 11's and not had any problems but heard they cause crashing in BF3. Not played BF3 for a while so can't really say.
I played bf on 12.11 beta 11 without a problem on 1100/1400 1.1v
