I will be ordering at the end of this ,month on the 29th so all subject to change. Im just working out a new build now with a lot of the parts you recommended
Black magic.......you know when you've been Hono'd![]()
Oh god the jokes on this forum have gone from bad to worse![]()
Right guys here is a build I have just been working on, let me know what you think as my budget is £325
YOUR BASKET
1 x Intel Core i3-3220 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £89.99
1 x MSI B75MA-P45 Intel B75 (Socket 1155) DDR3 Micro ATX Motherboard £53.99
1 x Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) £51.98
1 x XFX Pro 450W Core Edition '80 Plus Bronze' Power Supply £43.99
1 x TeamGroup Elite 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £35.99
1 x Xigmatek Asgard Midi Tower Windowed Case - Black £32.99
Total : £323.03 (includes shipping : £11.75).
True!, on that note, would you suggest buying parts in stage, for example the ones that arent too likely to fluctuate in price e.g. Case, Motherboard?
Is there any noticeable difference between pci-2.0 and pci -3.0? Or is it just a marketing thing?
You could but it only makes sense to do this when you have free P&P. You would need 250 posts to qualify for that which is do-a-bubble.
If you want to do "installments", I would look at doing PSU and case first. Then add a mobo bundle (CPU,RAM,mobo), that's enough to POST and test the rig. Then you can add the HDDs,SSDs,GPUs,optical drive etc etc
