Good enough for gaming and recording gameplay?
No, the 5450 is pants. If going pre-built (around a similar price), you'd want something like this:
YOUR BASKET
1 x "Titan 8700i Pulse" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Ivybridge Gaming PC £520
1 x No Operating System £20
1 x No Sound Card Upgrade £0
1 x Opt Out of FREE AV Software £0.01
1 x Standard Build Systems - Approximately 5-7 working days £0
1 x Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) £89.99
1 x Sapphire HD 7950 3072MB PCI-Express Graphics Card (11196-00-20G) with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games £239.99
1 x 24 MONTH WARRANTY - COLLECT & RETURN £0.01
Total : £888.60 (includes shipping : £15.50).
It should be arriving tomorrow so are there any recommendations? I already have another graphics card from my broken oc but not sure if it works. What should I do?
Everything else will run anything you throw at it, although it may be a bit overkill. The graphics card is the thing that is letting it down though, what graphics card is it that you have already?
EDIT: Finally, the modular PSU is in stock :D
OPERATING SYSTEM:
Windows 2.6.1.7601 (Service Pack 1)
CPU TYPE:
Intel® Core™ i5 CPU 760 @ 2.80GHz
CPU SPEED:
2.81*GHz
SYSTEM MEMORY:
3.99*GB
VIDEO CARD MODEL:
ATI Radeon HD 5700 Series
VIDEO CARD MEMORY:
2.74*GB
VIDEO CARD DRIVER:
aticfx32.dll
DESKTOP RESOLUTION:
1920x1080
HARD DISK SIZE:
465.76*GB
HARD DISK FREE SPACE:
273.56*GB (59%)
My exact old pc spec if it helps
That does look very good, I will try to get that but is there anything atall same quality but cheaper? And would I be able to use my 5750 gpu and the 5450 gpu together?
