Build log of "Unobtainable" - X79 in a white Bitfenix Prodigy
OP
26 Sep 2012
Thanks all :D
Could you use the 5.25 bay with the big 200mm rad??
Possible, you would have to do some modding to get it working :cool:
Probably best build I have ever seen. Looks amazing, and you are one skilled guy to put that together. I struggle in a XL-ATX Case never mind a ITX lol.
Thanks, My next build will be in a smaller case, but might not as compact..
Time will only tell :eek:
Not a bad looks pretty tasty!
You might want to check out this video the guy is doing the same sort of build you did but I thought you might be able to get some ideas from it (he's using the same water pump you are and a similar reservoir).
I really love the way he's used Bitspower Crystal links for the tubing.
Yes it is a nice clean build ;)
19 Oct 2004
London
What distance would you say there is between the end of the 7950 and the 200mm fan at the front? I'm thinking about my own prodigy build and want to make sure all the bits will fit...
