Doing it this way makes it very difficult to get it working with other operators, even after unlocking. I wouldn't bother. I'd either wait til they are available unlocked from P4U/CPW (which shouldn't be long) or get one from online somewhere.
anyone played QONQR? It's a gps based mmo for wp 7/8, quite nicely done and fun to battle over your local areas as it uses real maps and places as control points.
Just installed and quickly gained level 5, but I can't figure out how to build a second base![]()
Had no problem getting mine unlocked and working fully with 3. Just needed to install Nokia Access point from the market place so you can setup your apn.
I say go for it.
[RXP]Andy;23482528 said:I am stuck on that as well, I am just over level 10 with my crusade.
How did you manage to install it? As far as I was aware it wasn't possible.
EDIT: It's not just as simple as that though. You may find that being EE specific firmware that certain functions/settings have been removed/hidden due to EE not wanting them. At the end of the day it's his choice but I wouldn't.
[RXP]Andy;23482091 said:New EE firmware is showing up on DPM 1232.5951.1249.1017![]()
Anyway of telling if this is the portico update?
Not sure this will be as appealing but the 920 successor should have aluminium body and be thinner and lighter.
http://www.theverge.com/2013/1/3/3831420/nokia-catwalk-future-windows-phone-aluminum-body
[RXP]Andy;23484232 said:It is from the version number.![]()
Think it's worth flashing or does this mean we are only a few days off an official release? I've noticed when I go to check for updates I get the error that it cannot check at this time.
I will, Im going to try Nokia UK support first and then Germany as a last resort..
You can only build a base when you are actually located in that area unlike attacking defending when you can be a bit further away.
I have 4 bases, and about 16 areas, I'm purple and have an unspoken alliance with green, we both attack red but not each other, I have tried to contact him though.
Anyone else find it absolutely destroys their battery? Phone gets real hot too.
Has anyone got any recommendations for a wired charger? iirc it's 5v 1A? (Want a spare for work.)
