- 7 Mar 2005
- LU7
Indeed. There's an Edwin Jagger one on Shaving Shack for £65! Thought I would ask in case people knew of a quality one for a decent price.
Every god damn every time I decide to go and order everything they are always out of stock of the Edwin Jagger and Merkur 34c, they always seem to never have them!
The DE89L isn't adjustable. I'm not sure I'd recommend using a feather as a first blade without getting a bit of practise in first. The feather blades are pretty much the sharpest available and as you say, unforgiving. With a poor technique a feather blade will shred your face![FnG]magnolia;23514901 said:go straight to Feathers if it is an adjustable. Feathers are unforgiving blades if you're careless or too keen but will give you the smoothest shave without spending significantly more on blades.
Stupid question, but I assume you take a little soap on the brush, then using the bowel to "froth" it up, use then just rinse the bowl out?
Feathers is what I would aim for, but having a lighter beard it made more sense to get a good average shaver and see what kind of results I got, for me it might be enough, plus always an option to go by a better razor down the road.
