Yes. Everyone will have weapons of mass destruction.
You get my point though? If they were somehow made available cheap and easy, should people be allowed to have then just in case?
Not really, in terms of school shooting a handgun is much the same as a rifle, I don't think there has ever been a mass killing where range was an issue, they are all malls, offices and schools.I don't think they're evil, the point is obvious though surely?
A fist could kill a single person if hitting the right spot or if done for long enough, a knife will make that quick and easy, maybe you'll get two or more if taken by surprise, a handgun will making killing at a distance now possible, increasing the number and chances of a whole group dying, a semi automatic just continues the trend.
You suggest my point is flawed by posting something ridiculous?Either way your point is pretty flawed, on your terms an RPG is no more dangerous than a pistol. You only get one bullet and you still have to reload?!?.
In terms of people shot in the time available you could do exactly the same with a bolt action rifle.
15 rounds in 60 seconds.
Amazing. Go look up strawman
Either way your point is pretty flawed, on your terms an RPG is no more dangerous than a pistol. You only get one bullet and you still have to reload?!?![]()
It really isn't. You can kill an awful lot more people an awful lot more quickly with an assault rifle than with a pistol.
In terms of random or mass killings, yes. The rate of fire is much the same.Then by your argument handguns are just as bad?
'handgun and semi automatic' actually, it's not hard to quote correctly.You said a pistol and semi-automatic are the same because on both you pull a trigger and a bullet comes out. Go luck up ridiculous.
OcUS?I bet on an American forum somewhere everyone is saying the opposite to us.
