I know, and I think you've interpreted it incorrectly. Given there's a chunk of tail on a nearby building, it suggests that it clipped the crane and then carried on inland, loosing height before hitting the ground.
On the other hand, if the crane had been clipped, it'd bend, drop downwards and skim the sides of the building as it fell - which would take sometime (30 seconds?) as it was attached to the building by stays and cables.
However it is nothing that ATC could have stopped him from doing, just for clarity. From what I believe, the main helicopter route is along the Thames, and St George's Wharf is on the banks.Just been reported that the pilot was no longer speaking to ATC. Must've been handed off to Battersea and maybe decided to cut the corner.
Reports that the fog came down very quickly pilot poss had to lower altitude in order to get visual ground references.
I know nothing about this, but wouldn't you go... up?![]()
Not if your looking for ground references
Isn't it odd that he wasn't talking to ATC given he must have been about to enter Class A airspace?!He was twin-engined so yes, No requirement for him to stay on the H4 route. But with the vis being as it was it probably would've been better for him to stay on it.
No, I meant just if you didn't know where you were, over a city like London, would you go down for ground references? Isn't there anything else they can rely on?
Also, speculation is that G-CRST was the aircraft involved.
Yay time for days of speculation from armchair pilots.
Plus speculation form actual pilots, Police, emergency services, accident investigators, reporters etc etc etc
