It doesn't work for me in some games either, with BF 3 I can't get it to work at all, this includes FPS, sweetFX and sweetFX doesn't work with sleeping dogs but FPS etc. works (manually adding the sweetfx files for sleeping dogs works fine though).
Works fine here. I just create a BF3 profile, then select dynamic vsync and switch off ingame vsync.
If you go into settings where you can select witch corner the FPS counter will be shown you can there setup a hot key I use ctrl+F for enable and moving around the counter.
For sweetFX I just leave the file inside the BF3 game folder and it works am sure over on the guru3D forums its been said there is an issue with sweetFX not working correct.
Yeah, i read that, it wont work on the 64Bit RadeonPro, there is a x86/x64 link on the bottom left corner of RP's window, clicking on it switches it between 32Bit and 64Bit, still will not work.
Maybe i have to physically install the 32Bit instead of the 64Bit, it would be nice to get that working, it looks like once its connected you can make adjustments to it and play with it.....
How do you disable that annoying window that opens at login talking about the 64bit program and saying "there's nothing else to do here"? Bugs the crap out of me every time
Tbh I have found sweetfx extremely easy to install onto readeon pro all you do Is download sweetfx unzip into a folder of your choice then go to radeon pro click the browse folder option in the sweetfx tab click on the folder you put sweetfx in open done all the options become available in te sweetfx panel and you can adjust there also you can download already made profiles for games from here:http://sfx.thelazy.net/games/ (only site I've found so far if anyone has anymore sources I would appreciate it if they could share them)
Again all you do is download the file stir where u wish then in radeon pro in the sweetfx tab click import find the folder you stored the file click open and voila!
I had problems using sweetfx in dead island caused thin black lines all over the place (walls,floors!) batman seems fine looks so much better with sweetfx enabled and with my tweaks.
There is no folder tab, simply Import settings, that's it.
First off you need to tick the box to enable sweetfx as currently u haven't got it activated also in te settings menu u have a enable sweetfx option in there also I believe.
Also don't forget to click either the global profile or your own customised profile
Humbug once you have chose OSD make sure you also choose where it is displayed top or bottom that was a mistake I made! Also you have to go to settings and then advanced to choose a hotkey! The main mistake like a say I made was not choosing top or bottom on the OSD tab.
