I’ve been driving around in a 2002 Focus Ghia 1.8TDCi with 140,000 miles on the clock for the past 6 months after running out of money keeping the Monaro VXR going, which went in September. I had owned it for 2 years so I wasn’t that gutted when it went.
Things are much better now, I’ve cleared debts and I’ll have enough money to buy a new car at the end of March so I’m starting my search now as it'll take several weeks to decide what I want, then to find what trim level/engine I want and then find a decent example of the chosen car in the spec I want.
A few musts,
Some of the cars I’ve been looking at with a keen eye are,
Megane RS250
Pros
BMW 13xi
Pros
Astra VXR
Pros
Golf GTi
Pros
I looked at the Focus ST but I think it'd be too thirsty especially if my mileage increased.
I'd really appreciate some feedback from owners of these cars, I know we have several owners for each of the cars. What things should I look out for when buying? What other options can you think of?
A few musts,
- Under 60,000 ideally as I’ll be doing upwards of 20,000 miles per year and plan on keeping the car for 3 years.
- Combined fuel economy of 30+ MPG and a highway figure of around 40MPG
- Under 4 years old
- Had the option to include Sat Nav, Climate, Xenons and Auto Lights and Wipers
- Top end of my budget is £15,000
Megane RS250
Pros
- Fast
- Looks fantastic
- Quite easy to find with some spec under £15,000
- One of the best handling FWD cars
- Cheap to run bar tires and brakes
- Build quality will be below the BMW and Golf
- Large wheels may impact ride quality
BMW 13xi
Pros
- Fast
- Very easy to find in a high spec under £15,000
- German build quality
- Nicely balanced RWD chassis
- Most expensive to run?
- A little boring to look at
- Hard ride?
Astra VXR
Pros
- Fast
- Cheap to buy and cheap to run
- Easily moddable to handle 'decently'
- Looks fantastic
- At stock it’s the weakest of the 4
- Build quality is below the others
- Hard to find any with any spec what so ever
- Owned by rude boys so equally hard to find an unmolested example
- I've already owned a fully modded one for two years
Golf GTi
Pros
- The best all rounder of the 4
- Quick
- Well built
- Easy to find with a high spec
- Plenty of power and handling upgrades
- Relatively cheap to run
- A bit boring in the looks department
- A bit too sensible maybe?
