New Gaming Build
Also what resolution is the screen? I take it by 40" you mean its a TV so prolly not over 1080P.
If he wants to game in 3D he may well have to set it to 720P in game. The FPS are locked to the refresh rate. 1080P 3D on my samsung 40inch TV is 24Hz so FPS wont go higher than 24FPS which is poor as we all know. At 720P it's 60Hz so allows upto 60FPS which is much more acceptable
Was going with a blue theme with the mobo a little~but shall look into it thanks (im a freak xD)
1920x1080
In that case he won't ever need 2 GPU's. So he could save a lot of money by getting a cheaper mobo and PSU :)
750W Will be ample for 2 Gigabyte WF cards, I run one in my system and get 330w full load from the mains with the CPU & GPU stressed.
Thanks for the advice indeed this was what i was looking towards~ shall see what kind of results i may get but could expect them same
No worries bud. It stumped me for a bit, it's a limitation of the HDMI 1.4a interface. If this is a build for the lounge/front room I'd probably spec something like this as a next gen console killer.............
YOUR BASKET
1 x Gigabyte GeForce GTX 670 Windforce 3X 2048MB GDDR5 PCI-Express Graphics Card £319.99
1 x Samsung 256GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD256BW) £189.98
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x Gigabyte Z77N-WIFI Intel Z77 (Socket 1155) DDR3 Mini ITX Motherboard £98.99
1 x Antec Kúhler H2O 920 High Performance Liquid CPU Cooler (LGA775 / LGA1155 / LGA1156 / LGA1366 / AM2 / AM2+ / AM2+ / AM3+) £82.58
1 x LG BH10LS38 10x BluRay-RW / 16 x DVD±RW Lightscribe Drive - Black (Retail) £79.98
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £78.98
1 x XFX Pro Series 650W XXX Edition Modular '80 Plus Bronze' Power Supply £69.98
1 x Corsair Vengeance Low Profile 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (CML16GX3M2A1600C10) £59.99
1 x BitFenix Prodigy Mini-ITX Cube Case - Arctic White £57.98
1 x Microsoft Xbox 360 Wireless Controller - PC / Xbox 360 (JR9-00010) £24.98
Total : £1,258.44 (includes shipping : £12.50).
16GB for gaming is OTT but this mini-itx mobo (with wifi) only has 2 DIMM slots so i've gone with a 16GB dual channel kit from the get go. The pad comes with a wireless receiver for the PC, if you use XBMC as a frontend at startup you can navigate it with the pad, you can even launch steam (in big picture mode) from XBMC.
Keep in mind that to play non 3D titles in 3D you need to buy the 3Dplay driver from nvidia (you'd have to pay to get a driver for AMD GPUs too). Some games natively support 3D like Crysis 2, I'd imagine Crysis 3 will do too. You can download a trial of the 3Dplay software before you buy to try other titles in 3D and decide if it's worth your while.
Hope this helps
You don't buy the driver for Nvidia.
The 3D stuff comes with the normal driver, it's the emitter you've got to pay for, a long with an Nvidia certified 120HZ monitor.
For AMD, you'd just use Tridef (Which comes with quite a few 120HZ 3D monitors anyway)
He has a 3DTV he wants to use Martini, which is why I was talking about the 3DTV play software. I used the trial, never paid for the software in the end. As I said some games natively support 3D anyway so don't need the software for those titles
I swear to God I'm losing it.
There was an itch in the back of my mind as to why you said 3D Play.
I'm usually well on the ball, :p
Yes mate you are :)
It's partly my fault for not using the correct name, I was trying to recall it from memory. I've stopped being lazy and provided the link to the software now. As I said I've got a 3DTV and I run my HTPC through it, so I have some experience with all this faff lol
P.S I meant on the Ball not that you are losing it ;)
