Password Managers
18 Oct 2002
So.. I'm after a password manager app that I can put on my iOS devices, my Mac, and my windows laptop. I want something that will sync between the devices.
I've seen a few out there, and mSecure fits the bill nicely, apart from the fact I'd have to pay $19.99 for windows laptop, $19.99 for my Mac and then £6.99 for my iPhone and other iOS devices !
Has anyone got any suggestions of others that fit the bill, but not quite so pricey?
KeePassX and Dropbox works nicely.
KeePass and Dropbox.
Can't recommend this enough, and if you feel that the security of KeePass database file isn't enough, you can always store it in a small TrueCrypt container (or anything similar, but then you probably won't be able to use it with iOS/Android devices) before uploading it to Dropbox.
LastPass works nicely for the short moment I used it, but I found KeePass to be much cleaner in my option, so I stayed with that.
I use KeePass, but found a slight issue with storing the files in dropbox.
If you do this, and forget the dropbox password, well, how you gonna get use it :p :D.
KeePass. The database is synced using Dropbox. Enable key file support (this mustn't touch Dropbox).
iPad & iPhone: KyPass (supports Dropbox & key files).
