- 6 Feb 2010
Have you looked at the one Mr. May suggested on post 18?Think that looks like it, but that case isn't one of the passive ones...I have to get someone like the fc8
To summarise other people's posts. I would suggest:
YOUR BASKET
1 x AMD A10-5700 3.40GHz (Socket FM2) APU Trinity Quad Core Processor (AD5700OKHJBOX) £91.99
1 x Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) £85.99
1 x Impactics C3LH-B Mini-ITX Case - Black £84.98
1 x ASRock FM2A75M-ITX AMD A75 Chipset (Socket FM2) DDR3 Mini ITX Motherboard £73.99
2 x Impactics 130W AC-DC Power Supply Adapter £59.99 (£119.98)
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (TXD38G2133HC11DC01) £39.95
Total : £508.88 (includes shipping : £10.00).
If you feel you need more storage space I suggest you should adjust the ssd providing your budget allows! Completely passive machine.
Where is the cooler?
The case is the cooler but you also need to buy the heatppipe kit as I've said before! Especially with the impactics case
