Wolvers, that looks far from fine to me (not having a dig). Spikes of over 150ms and even over 200ms in one place shows it isn't.
If I have misunderstood your post and that isn't your chart, my apologies.
Fair enough. I need to do some frame times with these 310.90 drivers to see if I get the same. They feel horrid to me in BF3 and Far Cry 3, so possibly Nvidia are prone to this frame latency issue.
I will run a game I consider smooth and compare to a game I don't and compare.
See above Wolvers, there are rumours going around that TR's 7950 was faulty.
The results on the following pages come from the MSI card. As you'll see, its performance under the Catalyst 12.11 beta drivers is very similar to what we saw from the Sapphire, with the same latency profile and the same intermittent spikes caused by high-latency frames.
Have you tried with one GPU?
Greg how did you get the other things to work with frafs bench viewer? When i drag the fps or minmaxavg results there it says invalid column or something.
) is a little bigger so it looks smoother. That's one of the things you have to watch for in those TR reviews. TBH, I don't think they fully understand how to interpret this data properly yet.
Yeah, the default is 60 seconds and I just left it at that.
13.2 beta never lasted long though as I woke up this morning to see the wee man playing Spore-it was artifact city although he was playing it just the same, so back to 13.1's, but thracks did say not to use them as they were not complete.
Fair play to AMD with all the betas, but not much use when you end up rolling back due to the various small niggles you get, but they are betas at the end of the day.
FC3 is smoother on the 13.2's(but still the checkerboard bug in 3D that appeared from the betas) but the cut scenes are juddering again, Hitman has a massive improvement too-~60fps average fully maxed@1080p-at the expense of the high fps spikes and Skyrim has been given the smooth treatment too.
so are the 13.1 drivers worth the install?
.Thought I would add this here:
Installed 13.2 last night.
