Budget HD TV With Built in Freesat and DVD player?
21 Apr 2011
OK, so I am looking for a budget TV (<£100) with built in freesat, DVD player and HD.
Does such a thing exist?
I have found a number of TV's that fit the above but with freeview and not freesat, but I do not have a TV ariel and the room where it is to go has a cable to my dish.
Needs to be 20"-26" screen.
Can sacrifice the DVD player if need be.
Boo, thought that might be the case.
What about cheapo HD telly, built in DVD? I can get a cheapo freesat box.
Full HD and DVD: Not for under £100 I wouldn't have thought. Well, not regular sales stock. Maybe an EoL or refurbished model perhaps...
Stretch to £120 and you can get a new DGM brand 22" set which ticks those boxes. The model is ETV-2293WHC. Freeview tuner built in, but not Freeview HD or Freesat HD. Once again, too little money for the features you want. Either up your budget or adjust your expectations to a more realistic level.
Just found this which I might go for - 19" but thats not so bad given the rest of what it has. And since its not me who will be viewing it :D
Buy a 2nd hand one at that budget, used TV's are worth so much less than new ones that you might get something reasonable.
Thanks for the find but... That would be great if it had a DVD :/ The freesat PVR is nice, but wasted as I wouldn't be able to use it :(
Hmm looking at that site there are some with DVD's in too for £110 :D
Actually, you know what, for it being 22" and having full HD I might as well just get that one for the sake of £20. Just a shame there is no DVD but hey ho, its not essential. Got a Xoro freesat PVR on order too :)
Did you bother Googling for the DGM ETV-2293WHC which is 22", full HD and has a DVD [player built in.... or did I just waste that effort answering your query??
I must have missed that in amongst the posts... thanks for pointing it out and thanks for the pointer. No real need for the attitude though was there?
